r can't switch it on, down is always off,
The Fireman's Switch to cut power to pumps at petrol stations used to be ( and may still be ) Push UP for OFF so they could be switched OFF by a simple stick
OK another odd one out, but unless some helicopter lands on it unlikely to switch on with something falling on it. Unless building falling apart when I would think electric is least of worries.The Fireman's Switch to cut power to pumps at petrol stations used to be ( and may still be ) Push UP for OFF so they could be switched OFF by a simple stick
[/urlThey still are, and off=up is a requirement in BS7671.The Fireman's Switch to cut power to pumps at petrol stations used to be ( and may still be ) Push UP for OFF
First error was employing whoever wired that rats nest
Comments which you entirely single-handedly brought upon yourself.That’s ****ing obvious! Do you think any electricians are going to actually answer the question or just make sarky comments?
If you go back and look at my posts, you will see they are all questions, not statements so there was no need for a sarky reply. Anyway, who asked you to poke your nose in?Comments which you entirely single-handedly brought upon yourself.
You did.If you go back and look at my posts, you will see they are all questions, not statements so there was no need for a sarky reply. Anyway, who asked you to poke your nose in?
I tend to avoid guessing where I don't know, and trying to contribute in areas outwith my competence.I see you haven’t replied to the OP's question ‘How many errors can you spot?'. At least I had a go. Are you that sad and lonely that all you can add to this post is more sarcasm? Get a life.
You think?I tend to avoid guessing where I don't know, and trying to contribute in areas outwith my competence.
