Perhaps you should have posted the topic in the correct forumHe has correctly guessed that I am in Ireland
You have the flag on your username box.He has correctly guessed that I am in Ireland
Then the switch must be faulty.The wiring in the diagram is correct, here is a photo
Similar, maybe, but it doesn't matter. It is a very simple job - but things are not as they should be.My setup looks similar to this thread, presuming the blue line is hot (using a voltage tester, it appears to be).
Very wise.I'll get a sparks to look at it, was hoping to avoid as it's just a simple switch, but better safe than sorry
I can assure you that I am in Ireland.Sadly that does not always mean anything. Risteard has one as well but he is in the U.K.!
Perhaps geography isn't your forte GeorgeCooke.
My geography is OK. Derry, also known as Londonderry, is without doubt in the U.K.I can assure you that I am in Ireland.
No I don't. That is the flag of Ireland and not of any partitionist statelet. Perhaps you don't understand the history of the tricolour.If you live in Derry, you have the wrong flag in your profile.
