- Joined
- 8 May 2017
- Messages
- 10,554
- Reaction score
- 2,819
- Country
Fit full bore isolation valves . Its quite simple to work out how much needs to be cut out of your existing pipes to accommodate isolators. Just measure how much pipe goes into each end of the valve. For instance ,if 15 mm of pipe goes into each end ,you cut out 30 mm of pipe. Using a wheel cutter will make it very easy.
