Rigid waste pipes makes for a neater and more professional job ,and offer less resistance to flow ,and as the inner walls are smooth are less likely to hold solids and blockages.
However they do come in useful ,and in your circumstances won't cause any problems and behind a pedestal ,not to conspicuous. And will solve your misalignment problem fairly easily.
Thanks Terry. Ummm... any chance you could point me at the right one on Screwfix? I get really confused trying to pick my way through 1¼", 32mm, push fit, compression fit etc
What I have at the moment (if you can't see it in the photos) is the Floplast pedestal trap, with what I guess you'd call a compression fitting at the bottom? Tapered rubber washer, tightens onto the grey pipe which comes up out of the floor - except it doesn't, because of the angle...
So if I get a flexible pipe, presumably the end of it which fits to the bottom of the trap would need to be something else now, as there's nothing to compress on, if you get me?
