New spur socket
30 Jul 2008
Staffordshire
Hope sketch is clear.
I’d like to spur from an existing socket to a new one in another room.
‘Easiest’ route is through wall behind existing socket into another room, chase wall round internal corner, along wall running perpendicular to it and drill through to new socket position.
Is this within safe zone regs?
Yes, but one of the sockets is on the other side of the wall.
You would need to chase the wall on the existing socket side until you get to the corner in the new socket room.
Think the other way round.
Run cable horizontal from existing socket to wall corner. That is in zone.
Drill through corner into room two. Run cable horizontal from corner to new socket. That's in zones too.
And as I said safe zones don’t go round corners.
Yes they do when you have fittings on both walls and they are in line.
Which is not the case here.
For once in your life WINSTON will you read what's being suggested?
and stop makeing a fool of yourself
STOP BEING SO RUDE. Safe zones don’t go round corners (FACT) which what the OP wanted to do. What was later suggested may be OK but is not what was originally suggested.
To the MOD's: Please feel free to delete this post and equally feel free to reprimand SUNRAY if this post is out of order.
Dear WINSTON1
It's not me making incorrect posts.
OP has come here looking for advice on the way to do the job properly and safely, which is what this forum is all about. Having useful suggestions and correct information contradicted is very counter productive. Especially as you have not offered any advice or a solution to the question.
My post was aimed at your incorrect response in the order you made it, just read the whole thread, in order, and then tell us you have not made the mistake I have highlighted.
As I see it, at least 4 others are in agreement with me and as far as I can see, no one has agreed with you.
5 to 1 seems to be a pretty high majority.
No one is in disagreement with the later suggestion, but the original one is wrong. Simples.
