We've got a standard water tank with a bottom element fed from the economy7 wiring, and a top, "boost " element wired to the standard wiring.
Unfortunately it's quite a small tank and if someone has a bath in the morning
there is no hot water left, and the boost only heats the top of the tank so not enough for the rest of the family/day.
I was considering ways to "Boost" the main element, but obviously, just wiring to the same element would backfeed the economy 7 wiring, and could supply a nasty surprise for someone in the future, so it seems to me, the only sensible arrangement would be to use a suitably rated double pole 2 way switch to connect either the economy 7 wiring or the normal mains to the element, or rather to the fused switch feeding the element.
I know this will work, but is there any reason I shouldn't do it that I've missed ?
