Need a battery powered sander is dewalt multi tool good enough
22 Nov 2018
Cant decide whether to get the dewalt battery multi tool for outside sanding or the battery powered sander only? Which is better?
if you have say a bit off furniture and plenty off time eventually it will get done no good for large areas
the sander you choose is dependent on average use
Ok so I take it they are rubbish Sanders but are they useful for other stuff? I am going to fit laminate soon which will be higher than previous stuff i had
they are a brilliant tool for cutting into confined areas and also flat to a surface that can can also sand so dont think useless tool
Masonry requires specialist sanding pads.
The cheaper ones are silicon carbide.
The more expensive ones are diamond.
I didn't know that. I guess I can buy these for multi tool or sander in screwfix. Thxs
