I think that you're really only telling us what we already know - that a BC body (e.g. a LABC) will not issue an EIC (because, as we know, it cannot, since it didn't carry out the work, and therefore could not sign the declaration) - but that's nothing to do with the question of an EIC being provided (or not) by the person who did carry out the work.I knew I had it some where, so where the work is done by some one not trained to do inspection and testing no EIC will be issued, all you have or need is the completion certificate. It seems the certificate issued is not called an EICR it is called a "final certificate". This is where I found it there have been some changed I think now you need to pay for the inspection.
Looking back to the original OP, I think I've probably been misunderstanding the situation. I had been thinking that the work was undertaken by someone who could/should have provided an EIC, but who simply had 'disappeared' before providing one. Now looking back, goodness knows who did the electrical work, because I now see that the plan had been that someone else ("the Builder's Electrician") would 'certify' the work. Given that this other person did not do the work, there was clearly no way that he could ever have provided an EIC without lying through his teeth. That "Builder's electrician" is apparently now saying that he cannot issue an EIC because the work (which he only 'vaguely recalls' being told about) was carried out more than 30 days ago (not a consideration I've ever heard about), whereas the truth is that he could not, without falsifying the declaration, issue an EIC even if the work were completed yesterday.
frank999: You asked me "Without the EIC who takes the responsibility for this ?" but, to supplement what I replied before, can't you see how the answer to that is influenced by what I've written above? It seems that you would probably have been happy (that someone 'was responsible') if, as planned, the Builder's electrician had provided an EIC yet, since he did not (as I now understand it - is this correct?) carry out, inspect or test the work, that EICX would have contained a totally falsified declaration - and hence would be meaningless in law. I wonder if you (frank999) have actually seen the declarations which someone who provides an EIC has to sign? ...
