- Joined
- 27 Jan 2008
- Messages
- 29,245
- Reaction score
- 3,588
- Location
- Country
It is so easy to make a mistake, so "no from the bottom" was referring to where wires come out of the consumer unit, not out of the MCB, but "with the bus bar" clearly shows you had not realised what was being said, not totally your fault as clearly a bit missed, however it is far too easy to make mistakes like that, and clearly since you questioned it, you realised there was an error.
However I have done it far too often, some one at work has asked how do I do XYZ and maybe months latter I visit the house, and what I had intended them to do was not what they did, as to if I had not explained well enough or they had not understood does not matter, they had got it wrong.
From what has been said already I would say safer if you get it done for you.
