Just googled one. 13amp.
Fair enough. I just wondered, since even I did not think that what I'd written had really "cleared things up"No sarcasm intended whatsoever.
I'm sure there will be someone here who uses MK regularly and can tell us what's written on the back.
Thanks. I can't find any MK ones here, but have a selection of other makes, and absolutely every one I've got has got "13A" embossed on the back.Just googled one. 13amp.
Actually 14A and 6A.I believe that the BS 1363 test specification sets a maximum total current through a double socket to be 20 Amp. 16 Amp through one socket and 4 Amp through the other.
But this gives rise to another issue. 250V?
Quite so.is that an issue? - I read that in a similar manner to a capacitor, as it being its max tested value of: 13A @ 250V ... Would be less suitable if said 13A @ 220V and you used it on Isel of Man with its often 245V
14A and 6A actually, for one hour.I believe that the BS 1363 test specification sets a maximum total current through a double socket to be 20 Amp. 16 Amp through one socket and 4 Amp through the other.
Duration of test and maximum temperature rise are also specified
14A and 6A actually
