- Joined
- 27 Jan 2008
- Messages
- 28,951
- Reaction score
- 3,541
- Location
- Country
Yes but unless the heat is unwanted, be it light or heat it does not matter.more of the wattage used goes to generating heat
A bulb can convert electrical energy into many other forms.
Radio transmission, heat, visible light, etc, etc.
If any of them are unwanted, be it ultra violet, radio, or any other then that is waste. But both heat and light are wanted, at least in winter, we also want to stop energy escaping, likely most of the energy which escapes is through the window, be in inferred or light both can pass through most glass.
There is a problem with light, as it seems we are not equally receptive to all colours, we were told years ago the orange light was better for human eye, that seems to have changed, now they say green followed by yellow and blue. However erlands syndrome and Irlen Syndrome has shown a range of colours and frequencies can effect different people in different ways, so it is unclear as to best colour.
However we have long realised fluorescent lights can cause some people problems, and using a HF ballast helped with many of these problems, with LED it is a lot harder as bulb manufacturers don't need to declare if output smoothed, or at 100 Hz or any other frequency.
So even when people do have problems, which could be alleviated by a certain type of driver, because no one seems to know what driver has been used, only option is tungsten.
