| For volumes after the first 25m3- up to 20mm only | £0.9457 per cu.m |
You have to add the drainage/disposal charge as well, which up there is very high. Down here it's about the same as the water supply.
For volumes after the first 25m3- up to 20mm only £0.9457 per cu.m
Which is 220 gallons
if metered
Less than half a penny per gallon.
Metered Charges 2022 - 2023 - Scottish Water
www.scottishwater.co.uk
In summer we use around half a metre of gas a day, almost all for HWThat's for a metered supply and not for heated water. I thought we were talking about the cost of a gallon of hot water which would actually be the cost of the gas required to heat it from cold to the the desired temperature.
I don't care, I was just wondering.
It's massively more efficient to use a an electric kettle, in terms of energy losses, than to use a gas ring. Something like 3:1.
What I wrote stands.Except that efficiency losses in energy from the giant kettle in the power station, to the socket in your kitchen, are more than that, and you pay around four times as much for energy from electricity as for gas.
Our council takes general waste one week, then recyclables (glass/plastic/cans) another, food waste every week. Food containers are cleaned out and put in the bin, but with rising fuel prices, who will still be cleaning packaging (if you already do) ? Cost of hot water and all that.
You could take the dishes in with you, better still, go in fully clothed as well, kill 3 birds with one stone.
Here they are collected every fortnight, so in the summer it could get a bit whiffy. May be better now it's cooler.
What do you think a gallon of water costs?
If you are on a metered supply.That's easy - ignoring the standing charge a gallon costs me 0.64p
