If you are on a metered supply.
Which I am.
I said that because the rates given were from Scottish Water and, in Scotland domestic water isn't metered. So, the rates shown would have been for commercial supplies.Which I am.
For the largest part of my life I've lived in houses with no central heating. It was a coal or smokeless fire and an immersion heater that was rarely ever used because of the cost. If I wanted a bit of hot water quickly it was the kettle - for example in the mornings I would boil a full kettle for a cup of tea and a shave. Gas central heating is a luxury I've had for the last 15 years or so, and now it looks like I'll have to give that up - because of the cost of covid crisis. It won't be the end of the world as I have lived most of my life without it.It's massively more efficient to use a an electric kettle, in terms of energy losses, than to use a gas ring. Something like 3:1.
If you store HW in a cylinder it'll lose heat, plus you have wastes in the pipe runs. 5m of 15mm holds about 1.8l.
To get 1l from a combi you have to heat the boiler up first
If the lost heat gets used to heat your house, then..... get some back. (same argument as filament lamps.)
1 litre boiled in a kettle at 50p/kWHr costs about 5p if I've got it ric
1000 x 4.2 x (100-15)/(3600 x 1000) x5x50.
In summer we use around half a metre of gas a day, almost all for HW
Hw usage costs are trivial
But as cans and jars are sloshed in the washing up water, or rinsed in cold, and a few things go in the dwr, there is no additional cost
How much of that was for the gas?My gas has worked at at exactly £5.46 per week, for the past 9 weeks except for the one week at the end of July, where it hit £4.59.
You can get precise readings ; gas blokes have to check an applilance's consumption over 2 minutes. Difficult ones have buttons....gas meter reading are quite low resolution
Have you got some evidence that this is so please?I never have. Why bother, it will be cleaned anyway before they recycle it.
Care to rephrase that?It won't be the end of the world as I have lived most of my life without it.
Was there not an advert on TV that advised; "wash it and squash it"?From everything I have known councils insist that ietms are cleaned "before" putting into the recycling.
