Then your Helmet has failed, chuck it away,
It should darken, when the battery fails.
Actually, rereading the OP, Harry's auto-darkens (or not, currently).
I used to test mine by flicking a lighter - the sparks should make it darken automatically.i'm sure mine when I bought it didnt darken, I left it in the sun for an hour and then it worked fine. I always test if they are working before use by looking at a 240v light (the 50hz flicker trips them) sunlight or DC lights won't.
There's no risk, they have a fixed shade that is enough to protect your eyes anywayAlways wondered about auto-dimming welding masks.
So, they fail-to-danger?
Not a risk I'd like to take (with the old peepers).
On my Snap-On one, the screen is dark. I turn it on and it goes light. The millisecond I start welding, it darkens. Stop welding and it immediately lightens. I can adjust sensitivity as well as the amount of darkness too.
Crack it open and see what the battery voltage isMine has no switch, just 3x adjusters for delay, darkness and something else..
