You can calculate the maximum input pressure to the shower. Vertical height from water level in cold tank to top of shower unit on the wall in metres/10 gives your maximum bar (your supply pressure will inevitably be less than that due to pressure drop in the pipework.
For the flow rate I'd just run the shower into a bucket to start with on cold (to get a litres/min reading), if you want to get a unboosted supply flow rate as well then yes do that. Or try running the shower with the power turned off (that may not work though).
Just checked Mira's site- looks as though all of them will deal with low supply pressure (0.1 bar and less with the pumped showers).
