Is it really still £10?FFS, whatever you do don't take it to a tyre place for a ten quid puncture repair like a normal person would.
Good price. Where I am, it was £15 many years ago before the hyper inflation. Even then they could not sustain themselves and closed down.It is where I go, they also fit part worns - 25 for a good one, 35 for a very good one - so if the tyre is fairly worn and punctured I will usually get it changed.
£10 --- when was the last time you had a puncture repaired?FFS, whatever you do don't take it to a tyre place for a ten quid puncture repair like a normal person would.
£10 --- when was the last time you had a puncture repaired?£17 last week!!!!
We're running 3 cars at the moment so I might have to look into that gloop or that sticky elastic stuff.
There’s no way anyone would carry out a permanent tyre repair to British standards for a fiver. At best, you’ll get a temporary string repair without inspecting the inside of the tyre. Dangerous. I’d always recommend removing tyre, inspecting damage, plug patch repair, new valve and rebalance.It was £5 before COVID (
I've used it successfully on my lawn tractor, but not sure I would trust it on a higher speed vehicle.We're running 3 cars at the moment so I might have to look into that gloop or that sticky elastic stuff.
Crappy porous alloy perhaps?I just air the thing up to the correct pressure very 5-6 weeks .. can't be arsed with it anymore.
Possible I suppose, but the wheel looks to be 'as new' & the four on the car are now 36 years old & none of the tyres loose air.Crappy porous alloy perhaps?
Half a litre of tyre slime will probably put an end to the problem
You'll never, ever find a puncture that slow with a water tank. Use a solution of water and washing up liquid. Lay the wheel flat on the ground and soak the top edge around the rim with it including the valve. Wait up to ten minutes. If nothing, turn it over and do the other side. If still nothing, try the tread area. What you are looking for will not be decent sized bubbles of any kind but a creamy 'foam'. Be patient and you’ll find it. One of the common places is around the valve where it pulls through the rim. The rubber goes hard which is why it is good practice to replace the valve every time the tyre comes off. Check it with your valve extension on in case that is your problem.Whole wheel immersed in water tank by tyre fitters .. no bubbles.
The valve has been replaced & the rim re-sealed. The tyre was brand new & to date has never been on the road, also the pressure loss pre-dates fitment of the extension.You'll never, ever find a puncture that slow with a water tank. Use a solution of water and washing up liquid. Lay the wheel flat on the ground and soak the top edge around the rim with it including the valve. Wait up to ten minutes. If nothing, turn it over and do the other side. If still nothing, try the tread area. What you are looking for will not be decent sized bubbles of any kind but a creamy 'foam'. Be patient and you’ll find it. One of the common places is around the valve where it pulls through the rim. The rubber goes hard which is why it is good practice to replace the valve every time the tyre comes off. Check it with your valve extension on in case that is your problem.
