I did mention L-shaped in my op.So it’s fitted in a corner ? You didn’t mention that .
Yes I’ll use packers and no not biscuit jointed. It was a dry run that seemed to go well so I carried on without biscuits.
Then I found the out of level issue and the dip in the centre. Guess I’ll have to strip it down again, sort the bracket issues, biscuit joint the worktops and let’s see how it goes.
I would have used glue to put the biscuits in, but then silicon to join the 2 worktops.From memory... the person that I would defer to on this is @jobandknock, unfortunately he is MIA. From memory... I think when I asked for advice in a slightly similar situation, he recommended using silicone rather than glue for the biscuits because of the dynamic loads.
Does that sound acceptable?
Yes deffo in a corner from wall to wall, hence the batons along each wall and the idea to just use heavy duty brackets to hold up the worktop which remember is 28mm not 40mm thick, and no legs.When the OP said that it was L shaped, I assumed he was referring to a corner, but I can see why you thought otherwise.
Dust is black. Pretty certain they are cinder blocks. Drill bit slips a lot too, which I guess is why the plugs don’t properly catch in the hole even when the bolt opens the wings out when screwed in.I don't know the answer. I would be inclined to use silicone for the whole lot because it will be more forgiving once things start to bow/expand/contract.
Getting back to an earlier response. Is the dust grey or black? Your post was not clear.
Dust is black
Ok, sorry. My stepson has used the same brackets to hold up his worktop and that is solid oak.
It’s NOT L-shaped, but it is much heavier than my worktop.
I’m fairly confident that the brackets will work, once I get them properly anchored to the walls AND packed right to actually connect to the worktops.
I have thought about mounting the brackets onto timber, but the most troublesome bracket is behind a radiator and I had to angle grind a bit out of it to get it to fit. It doesn’t compromise its strength but I can’t baton it out because there’s no room.
You said top was L shape not fitted to corner.I did mention L-shaped in my op.
Assumption tends to lead to cock ups.It though be a fair assumption that it would be in a corner..
