Not obvious , he said it was only fixed to wall at rear. No mention of return , side wall .Except when it's an obvious assumption to make.
I did mention that the back edge was on batons fixed to the walls. Does that not imply it’s in the corner?You said top was L shape not fitted to corner.
No just the back edge not the side return.Ideally you would have said I want a corner desk fitted to the corner of my room.L shaped desk where the return sticks out into room are just a s common.I did mention that the back edge was on batons fixed to the walls. Does that not imply it’s in the corner?
So I have an L-shaped (2m x 3m x 635mm) office worktop (28mm thick), butt jointed using 3 easibolts.
Could still fit to walls with return into room.In the original post he said "walls", not wall.
So it’s fitted in a corner ? You didn’t mention that .
Why would he recommend silicon rather than glue in this situation? No Nails is an adaptable adhesive that could stick 'Solvite Man' to a board and fly him round the houses.From memory... the person that I would defer to on this is @jobandknock, unfortunately he is MIA. From memory... I think when I asked for advice in a slightly similar situation, he recommended using silicone rather than glue for the biscuits because of the dynamic loads.
