Hello, so as above really, I'm looking to connect my my Hive thermostat to my Ideal boiler but I'm a little confused at this point and keen to try and get some help if possible?
So, when I moved in our thermostat is an Ideal digital thermostat and we've now decided to change it to a Hive system and last night I've gone to get it all connected.
This is the original setup below.
I followed this cable at the top and it goes to this box
which also has a mains cable going to it as you can see and the direct other side of the wall is a boiler switch. I disconnect all of these cables above in the first image and connect the new Hive system using a 5 core cable into the room stat, live, neutral and eart ports however as soon as I disconnect the above original cable the boiler would not switch on and surely I still need that switched on for Hive to work? thanks!
so now I wonder, am I meant to disconnect this or should this be left connected? I tried it with it still connected and I connect my Hive 5 core cable into the room stat/mains live, neutral and earth however my ideal thermostat was still working and activating the boiler and I know I need to disconnect that for Hive to work..
Sorry if this is all a bit stupid just keen to do it myself and save the money that I really cant afford. Thank you!
