- Joined
- 26 Feb 2025
- Messages
- 4
- Reaction score
- 0
- Country
I new here and looking for some advise please . What is normally the size of wire going from the consumer unit to cooker switch ? I would very much appreciate any help . Thanks
What are you trying to do?
Doesn't have to be digital, could use Vernier calipersYou would need a digital measurement device (calliper) to discover the csa
*yawn*Or a micrometer digital or not
Oh right the Taylor lad - by the "rack of the eye" then if you are proficient in light engineering disciplines and have a handy steel rule to compare against.*yawn*
Oh yes. So it is simple to use a steel ruler to measure the diameter of a single strand multi-strand conductor, calculate the csa and then multiply that by the number of strands?Oh right the Taylor lad - by the "rack of the eye" then if you are proficient in light engineering disciplines and have a handy steel rule to compare against.![]()
| CSA | Overall Dimensions | Diameter of each Live/ | Number of strands | Approx Measurement across |
| Neutral copper core strand | bundle of strands (‘diameter’) | |||
| 1mm² | 7.8mm x 4.25mm | 1.13mm | 1 (solid core) | |
| 1.5mm² | 8.2mm x 5mm | 1.38mm | 1 (solid core) | |
| 2.5mm² | 10.3mm x 6mm | 1.78mm | 1 (solid core) | |
| 4mm² | 11.9mm x 6.25mm | 0.85mm | 7 | 2.56mm |
| 6mm² | 13.5mm x 7mm | 1.04mm | 7 | 3.13mm |
| 10mm² | 17.1mm x 10mm | 1.35mm | 7 | 4.05mm |
| 16mm² | 19.4mm x 10mm | 1.71mm | 7 | 5.12mm |
Just to add a 'disclaimer'Ahem from:
https://www.diynot.com/wiki/Electrics:cable_types:flatpvccables ...
.... The table below gives some typical overall cable dimensions for some standard flat T+E cable sizes. Note that cables from different manufacturers will vary slightly from these dimensions. Judging what cable size you have:
CSA Overall Dimensions Diameter of each Live/ Number of strands Approx Measurement across Neutral copper core strand bundle of strands (‘diameter’) 1mm² 7.8mm x 4.25mm 1.13mm 1 (solid core) 1.5mm² 8.2mm x 5mm 1.38mm 1 (solid core) 2.5mm² 10.3mm x 6mm 1.78mm 1 (solid core) 4mm² 11.9mm x 6.25mm 0.85mm 7 2.56mm 6mm² 13.5mm x 7mm 1.04mm 7 3.13mm 10mm² 17.1mm x 10mm 1.35mm 7 4.05mm 16mm² 19.4mm x 10mm 1.71mm 7 5.12mm
