- Joined
- 13 Mar 2025
- Messages
- 3
- Reaction score
- 0
- Country
Hello all.
I've recently qualified as a PAT tester with C&G. First post on here, so please go easy - all advice and feedback gratefully received!
I was testing a computer monitor in my office (fairly modern LCD type - very low power draw of between 29w and 72w according to the manual). The IEC lead with it has a 13A non-rewireable plug rating with a 13A fuse installed, but then has a 10A rated connector on the C13 connector. It is hard to tell if this is the one supplied by the manufacturer, but let's say that it was. The CSA of the cable is 0.75mm and so the 13A fuse meets with what's acceptable from the ITEE 5th edition table (10.6 pg80), but the connector being stamped with 10A has me confused, as well as the fact this cable is paired with such a low power draw device where a 3A fuse should be more than sufficient.
So to the purpose of my post: Is it advisable to replace the 13A fuse with a 3A fuse in this IEC lead to add additional protection to the monitor & cable? Granted, the fuse is to protect the cable and not the device I know, but I still wondered amongst you experienced testers out there, what would you do here? Should I leave the fuse as is, or swap it out for a more appropriate 3A fuse?
Many thanks in advance.
