I don't do iny of those but I do do EETing and that constitutes the visual inspection part.I'm not a fan of trip hazards. I advocate sufficient socket-outlets so that extension leads aren't required.
They're frequently used indoors.I don't think that the 'wound up' extension reels on drums or in 'cassettes' are often used indoors because of 'insufficient socket outlets'. They are most commonly used outdoors and/or in situations in which there are no (live) sockets at all in the location in question.
Maybe yours are.They're frequently used indoors.
Not sure I've ever thought about LED in terms of flourescent-tubes-worth, more that around 5W LED is what you'd put in your ceiling (GU10) and 20W would be an outdoor security light ..The impression I get is that LEDs are about 1-2 times as efficient as flourescent tubes
Given that it is now very common for portable appliances to have cords only 2m (or sometimes less) long, how many sockets is "sufficient"?I'm not a fan of trip hazards. I advocate sufficient socket-outlets so that extension leads aren't required.
Quite often used in domestic environments here.Normally, only in a working environment. Not normally in a domestic setting indoors.
I wonder if that's for the same reason that frequent use is seen in Australia.Quite often used in domestic environments here.
Are Irish houses so short of sockets?Quite often used in domestic environments here.
I have a garden, 120' x 30'.It's the only correct answer, as I'm not familiar with your installation or needs.
Are these industrial?The question has to be why would anyone, living in a normal domestic environment, in 2025, even need an industrial extension reel to be used?
No - the better option is for you to actually answer, instead of indulging in your usual practice of lies, misinformation, deranged advice and abuse and then melting away until the next time something triggers you and you decide to come in swinging your wrecking ball.The better option is to ignore your imbecilic and frequently racist posts.
The cable shall be fully unwound when in use.
So do you think people might have a use for ones like those in a domestic environment?I would suggest no.
