Quite simply, no one, but no one, will run a shower for in excess of one hour. In fact most will be in, and out within minutes - that is the point of a shower, speed for most people. The worst that can happen is that if you exceed the 'on time', is that the MCB/RCBO might eventually trip. Inconvenient, if you happen to still be in that shower, but perhaps a reminder to get out?
All MCB's/RCBO's, in the same range, are built with the very same internal components, able to carry the maximum current of the same range, all that varies is the sensing/trip components, suggesting that overheating due to overload, should not be an issue.
After decades of use of a our 9.5kw shower, supplied via a 32amp RCD, last year I decided it was time to upgrade our consumer unit with a larger item, including RCD's, and all new MCB's. Once that was done, out of curiosity, I took the opportunity to closely examine the old 32amp MCB, which had supplied our shower, and never once tripped. As expected, there was absolutely no sign of any wear, damage or any sort of issue at all.
