- Joined
- 27 Jan 2008
- Messages
- 29,070
- Reaction score
- 3,561
- Location
- Country
I have two AGM batteries which were in the car (95 Ah), no longer good enough to start it, but would run a lamp for a fair time, also two 35 Ah also AGM which were for the scooter, that is not used, and a 20 Ah brand new, in a battery pack designed to jump start, run a lamp, 300 watt 230 volt outlet, and a failed tyre pump.
The battery pack has its own charger, Walmart type, and the 35 Ah do have a 24 volt charger, but not really easy to use when batteries not on the scooter. Also, two stage chargers, but they will not auto start, one needs to press a button to start them charging.
If not used, they will fail, so better if used, I have batteries with my solar which will keep central heating and freezers running, but not lights, so considering how to use the batteries for lighting if we get a power cut, the battery pack easy, it has built in fluorescent lamp, and a 13 amp socket, but it is the other batteries, and how to use and charge them, without doing too much, as may with a bit of luck never be used.
So does anyone else use batteries for lighting with a power cut? Somewhere I also have a 150 watt inverter, and what I am wondering about is how much the inverters will use.
So ideas as to what is feasible using old batteries as back-up.
