- Joined
- 18 Aug 2025
- Messages
- 108
- Reaction score
- 3
- Country
⁴
Th
So on a other questionnwith regards to coming from a juction box in the loft to bring a new 13amp fcu whats the rules on this can you only bring 1 supply from one junction box and if you wanted another you would have to cut into the ring and add another junction box ?
But yeah covering my orginal question i though if you had a single run of 2.5mm coming from a junction box in a loft down to single/double socket you could then spur off that socket with a fcu and the add as many as you want but the ruling is you need to removed the double/single socket and replace it for a fcu then add your sockets aftwards which you have confirmed
but if the socket was on a ring showing by having 2L 2N 2E then it would be ok in that instance to then add a fcu so the socket would then have 3 cores going into and in and a out for the ring and then a cable off to the fcu
Again thanks alot for the help
I believe you currently have thisView attachment 397264
View attachment 397265View attachment 397266View attachment 397273
Essentially the simple rule is an unfused spur from a ring, be it from a socket or junction box etc may only be connected to one of these accessories: single socket or double socket or fused connexion unit. After the fuse in those accessories almost anything may be added.
Th
Thanks alot for the advise yeah so basically once you have a fcu on you can basically connect anything to the load side of the fcu obv aslong as you have the correct fuse in the fcuI believe you currently have thisView attachment 397264
