Adding a socket
10 Aug 2010
Leicester
Hi I'm adding a double socket and piggybacking off the 13amp fuse spur
Am i right in thinking the new brown and blue wires go in
L out (brown)
N out (blue)
what is the thin copper exposed wire?
Live. Neutral and earth.
That's 3 wires.
Please take this as my concern...
I'm worried about you messaging with that if you are unaware of this fact.
Get a electrician to wire up.
Engage an electrician,your existing wiring shows a black wire connected to an earth terminal and needs investigating by somebody qualified.
That's how it's been since the house was built I haven't touched anything
That brown, grey, black, looks like it is probably a three core armoured cable, feeding something? So the black is probably correctly connected, but should have been fitted with green/yellow sleaving.
Well I've had no joy connected up the additional wiring to L out and N out and tripped the whole house.
Could the tripping be a wire? It works fine until I close the spur up so I'm thinking maybe something loose?
Some of the copper conductors are sticking out from the terminals ,there should be no visible copper.
The red wire is hanging out of its terminal.
You shouldn't unscrew the switch plate from the mounting box with the power on either !
I'll trim them tomorrow it's hard to get the right length with such little space I don't know how sparkies do it.
It was the only way I could see if it was working before screwing in. I think it's a loose wire as the lights flicker. I've turned it off at the fuse on the main board until tomorrow then I'll recheck the wires
That wiring is AWFUL. Too much exposed copper, which would certainly cause the wiring to short circuit.
