That's how it's been since the house was built I haven't touched anythingEngage an electrician,your existing wiring shows a black wire connected to an earth terminal and needs investigating by somebody qualified.
Somebody has, there are new and old versions of the wiring colours present.That's how it's been since the house was built I haven't touched anything
It seems to be tripping when I screw up the fuse spurPost a pic of what you've done.
What does the fcu do?
You are probably catching something with the 3.5mm fixing pinsIt seems to be tripping when I screw up the fuse spur
I'll have another look tomorrow it's too dark now, I've switched the fuse off for the garage.You are probably catching something with the 3.5mm fixing pins
I'll trim them tomorrow it's hard to get the right length with such little space I don't know how sparkies do it.Some of the copper conductors are sticking out from the terminals ,there should be no visible copper.
The red wire is hanging out of its terminal.
You shouldn't unscrew the switch plate from the mounting box with the power on either !
Well it probably would be - it's 3 core SWA cable.Engage an electrician,your existing wiring shows a black wire connected to an earth terminal and needs investigating by somebody qualified.
That wiring is AWFUL. Too much exposed copper, which would certainly cause the wiring to short circuit.Well I've had no joy connected up the additional wiring to L out and N out and tripped the whole house.
Could the tripping be a wire? It works fine until I close the spur up so I'm thinking maybe something loose?
