BoschSeries 2 fridge door left open - no longer gets cold enough
There wasn't any dripping...
...that you could see. But melting ice turns to water.
Ice blocks the flow of cold air through the ducts.
Have you seen any evidence that the blockage has gone?
Maybe it hasn't melted yet. Or maybe it is draining somewhere you can't see. Frost free freezers drain the melt water out through a gutter and pipe usually round the back where it can evaporate from the heat of the motor,
I did feel in the drip tray at the back on the last defrost but it was dry. What baffles me is how it can reach 5 degrees and swing up to 8 Getting down to 5 surely suggests ice has cleared.
With respect, you really need to remove that white back cover. Run a hair drier over it for a few minutes. If it seems to be stuck, use the hair drier for a bit longer. It will help you to narrow down the possible fault.
Checking the drip tray really isn't going to help if there is a massive lump of ice behind the cover.
The drip tray may not actually get any water into it if the tube from the bottom of the back of the freezer has got blocked with matter/stuff.
Poking something long and flexible down it might help prove it's clear.
Well after a week of it averaging around 5-7 degrees it is now back up to 12. Why would it get worse ?
Ok, I have tske the panel off and can see so e of the fins look slighly bent. Can't be me as was careful. There is NO ice on the fins, just a little dripping water. Should I assume there is no ice I can't see deeper in the workings?
can you see a fan that circulates cold air through ducts?
Look in the ducts.
Also, work out where the dripping water comes from and goes to so you can see when it stops because all the ice has melted.
The fan is in the panel I just removed. I unplugged one of the clip cables but can't get the other off so supporting panel with cushion for now to stop it straining the wire. It has only been turned off an hour so there must have been no ice, just frost. Using hairdryer to dry it all out.
Interesting development. A rookie error but looks like our plastic thermometer isn't as accurate as thought this temp is of course after turning it off and defrosting.
Well done for checking it. It reduces the number of possible problems.
I would recommend posting your question to the UK white goods forum (telling them what you have done thus far).
If you do, please let us know how you get on.
I hope the mods do not mind me pointing you elsewhere, especially given that you will hopefully let us know how you get on.
Best of luck.
Well this is just so frustrating because after the relief of finding out the thermometer was way off, we buy food after switching back on after the defrost (which found zero ice incidentally) as it was in the 1-2 degree range. Now it seems to still jump about between 2 - 7 degrees just over halfway on the cold dial. Yes, after any door openings I get that it rises up briefly but this was after an hour left shut. Even more illogical as it was 4 the previous time.
So yes, it's much better but the stability seems to be off or is this normal ? Again, there was no ice on the coils at all so that is at least eliminated, Other than that I can't understand what it could be as the vents are clear.
Did you ever find the ducts?
Yes, when I took the back panel off the freezer.
It seems to be running normal again now, around 2-4 degrees. Phew! Just ordered 2 decent fridge freezer thermometers. The other is going in the bin.
Thanks for all your suggestions and help.
