I enjoyed comments like “they are not fluorescents they are CFLs!” Until you asks what the “F” stands for in CFLs?
Yes, but I remember testing one, with the old fluorescent they were very voltage dependent and just a little over voltage, and they use way over the rated wattage, this was where the electronic ballast came into its own, never opened a CFL (compact fluorescent lamp) but I did put one on an energy meter, and an 11 watt lamp seemed to use 11 watt whatever the local voltage was, so assume an electronic ballast inside?
The one which got me, was, bulbs go into the ground, it's a lamp, but the lamp is the whole assembly, it could have a wick, mantel or bulb, inside, but I could not find another word to replace the bulb, even if technically not bulbous any more, so should not be shortened to bulb.
But this is repeated with transformer, ballast etc, at least called an electronic transformer, what is wrong with calling it a switched mode power supply I don't know. Driver is another one of the words, it was used for a current regulating unit to power LEDs, then same word used by manufacturers for a voltage regulated DC switched mode power supply.
I made the mistake of ordering a head lamp, instead of a head lamp bulb, and I got a head lamp, minus the bulb.
