- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,436
- Country
Did you ever hear of a Dubai lamp?
I believe the tubes last longer than the LED's which seem to fail regularly.I have replaced may LEDs that failed after a couple of years.
I understand why people purchase them but the life expectancy quoted by manufacturers doesn't always seem to align with their claims.
There is that aspect to itI believe the tubes last longer than the LED's which seem to fail regularly.
If it's a common size, I'd convert it for use with LED tubes.No contest, it's not worth messing with, just replace it with a complete LED fitting. Some fittings didn't use/need a starter,
When it comes to LED bulbs for replacing incandescents there seem to be two main styles.I have two carriage lamps outside, one is integral and one has a bulb, it seems the integral one is far the better of the two, but it is really because the integral has the light at the top shinning down, and the bulb has the light at the bottom and shines up, use of a reflector has improved the bulb one.
But it seems although the LED bulb emits the light in a different direction, carriage lamp manufactories have not changed their design to suit.
Fit Filament LEDs.outside my carriage lights with bulbs, shine the light up, I have fitted a reflector, but most the light is waisted.
I use a smart bulb, so can switch it on before leaving car, and off once in the house, or I would use the filament type. Not enough room for a smart socket adaptor were plugged in, so no real option unless I fit a relay inside the lamp.Fit Filament LEDs.
