bathroom pull switch wiring
22 Jan 2007
Lancashire
im fitting a new pull switch in my bathroom , the one thats in now has 4 wires red and black into the load part and a red and black in supply part on the rose fitting, the new fitting has l1 and l2 and com-l can you advise where the original 4 wires go in the new fitting please
You have bought the wrong switch.
You nee to take it back to the shop, and exchange it for a double pole pull switch.
the switch operates a pully swith, which i am replacing , the one in the ceiling has 2 cables 4 wires,going to it, prsuming loops to a nother light, and i want to fit a swich that has L1 and L2 and com 1
It sounds like the original one is a 2 pole switch. It will make or break the circuit between the two reds (one pole) and the two blacks (the second pole).
The one you bought is a single pole changeover switch, the type used for a 2 way lighting circuit.
Buy a two pole switch of the correct current rating for whatever it is feeding.
a pic would be better, but if your blacks are neutrals you counld join them in a small connector block and put you two lives in C & L1, i am assuming its feeding a light not a shower
that is what is worrying, twice i have asked what the switch operates, and twice the OP has ignored it
softus, why would you think its stupid to assume its a light when funky monkey said "a red and black in supply part on the rose" and he also says "the switch operates a pully swith, which i am replacing , the one in the ceiling has 2 cables 4 wires,going to it, prsuming loops to a nother light, and i want to fit a swich that has L1 and L2 and com 1" The give away being "TO ANOTHER LIGHT"???????
FM:
When folk asked you "what does this switch operate?", they meant,
"What comes on when you operate the switch?"
