The 13 Amp plug fuse seems an odd standard to me.
Apart from cooker, hob and shower which have their own circuits and are not plugged in anyway, I have no devices or appliances in my home that will draw 13 Amps.
Even if I did have a 3 kilowatt fire, 13 Amps seems a poor choice for the plug fuse since 13 Amps is exactly 2.99 kilowatts at 230 Volts. Surely a 15 Amp would surely be more suitable. Thoughts ?
I do have a number of 2 kilowatt devices that I need to plug in. However, the 13 Amp fuse also seems wrong here too. It is far too 'generous' for the current being drawn. I am thinking of replacing my 13 Amp fuses with 10 Amp fuses for these appliances. Am I right ?
Finally, considering the final ring main 'trick' of being able to use 2.5mm cable for a 32 Amp MCB, what is the actual current that would actually blow a 13 Amp fuse?
Would a 13 Amp fuse blow at 14 Amps, or 26 Amps ( 2 x 13 ) ?
