3 pin plug to socket
19 Oct 2021
I've got a plan to wire a 3 pin plug to a wago box that will then feed 2 single sockets, one on either side of the bed (effectively an extension cable with fixed outlets as far as I'm concerned). I'd like to do this instead of a spur. Any reason not to do this as long as the plug is fused appropriately?
28 Jul 2006
Oxfordshire
No problem with what you plan, but why not just have two extension leads, each with at least two sockets. one short and one long.
Plug the short one into the wall socket, plug the long one into the short one.
No need to mess around with Wagos, etc.
CBW
26 Sep 2019
North
What size cable are you planning to use?
19 Oct 2021
No problem. Why not have two extension leads, each with at least two sockets. one short and one long. Plug the short one into the socket, plug the long one into the short one.
Primarily neatness and aesthetics. I've got a light switch on the wall on either side of the bed for bedside lamps which are wall-mounted and I wanted to have a socket next to them to charge phones etc. Rather than having extension cable spaghetti on the floor under the bed, I'd like to run additional cables through the existing conduit for the lights to power the sockets
28 Jul 2006
Oxfordshire
Trying to understand your expectations
You are planning to run sockets wired from the existing lighting switches. Is that correct?
CBW
26 Sep 2019
North
My initial thoughts were same as yours, but then I’m guessing OP means there’s already conduit with lighting wiring inside, and they want to run a separate cable for sockets in the same conduit.
19 Oct 2021
Yes that's correct. The lights run off one plug and I want the sockets to run off another - both from the same double socket with the wires in the same conduit
  • Thanks
Reactions: CBW
28 Jul 2009
Kent
2.5 t&e in conduit from the box and 2.5 flex to the plug
You don't need anything like 2.5mm²
1.25mm² flex is adequate for a 13A extention lead, if you are able to get 2 of those cables into one conduit there's no need for a junction box.
Additionally if these sockets are really only for charging phones etc then 1mm² or 0.75mm² flex could be used with 10A or 5A fuse in the plug.
19 Oct 2021
When you say no need for a junction box, do you mean I can wire them into the same plug? The idea of the junction box was to split the flex from the single plug out and then have one cable to each side of the bed with a socket for each. The socket I want to use to feed these is in the middle of the bed behind the headboard with one currently feeding a light on each side in the exact same configuration as I want for the sockets.
19 Oct 2021
Yes, you could do that if the cable fits.
I am puzzled. Where is this conduit you mention?
Currently wired to a switch on either side of the bed that controls a sconce light on each side. I want the sockets to be near to there (think how a hotel has sockets next to the bedside table
7 Jul 2010
Retired to:
Portugal
Yes, but they don't have accessible conduit.
