Sorry if these have been mentioned before, I did try a search but it was a bit unsucessful!
1) In House 1, I have just had a rewire (about 2 months back) as it needed doing. However I have just noticed that the new consumer unit (wylex) has a small 'nick' in it. It is on the corner at the top right on the cover part where it joins onto the backplate. It is about 2mm diameter. Should I be worried about this or can it be happily left? I can't say whether it happened during or after the install.
2) Also in House 1 I had a shaver point installed in the bathroom, however they put in one with a light, and I just wanted one with the 2 sockets that say Shavers Only and fit onto a 2 inch backbox. I have got the bits from a local wholesaler however my question is, can I take out the wrong one for the new myself? (what with Part P and everything, seeing as it is in the bathroom). I know it is quite a simple job. Also I can't see any IP mark on the unit. Should it have one? I explained clearly to the wholesaler where it was for. It would be placed quite a way away from the sink/bath etc.
3) In House 2 (in the kitchen) I need to move a socket outlet as the flex for the new fridge won't reach. I thought alternatively I could add a single socket about 1m down as a spur, but can I do that under Part P? Presumably I can move the socket myself....
The socket only has one wire going into it, so could be a spur itself or just on the end of a radial circuit. I am not sure. A lot of the sockets in my house (2) only have 1 wire going in, and a few have 2. It is quite old wiring and I would have thought is radial. Is it allowed to have a spur off a spur? (I know only 1 spur off a single socket, but can you take a spur off a spur?)
Sorry if these are 'simple' questions, but I don't want to break the law, and I want it to be safe!
Thanks in advance,
David
Thanks in advance,
David
