I think they must have cut (or broken!) a bit of an 'entry hole' for it in the back part of the box, so it may not be trapped - otherwise I find it hard to believe that a cable that size could have been squashed enough for the front and back bits of the enclosure to get that close together!At least the CPC will not work loose, must have gone to a lot of trouble to trap it under the lid
Indeed, very odd!Seems odd, having hacked out a great gaping hole 5x (or more) bigger than needed, not to use that for the cpc as well.
Never assume! (particularly not when looking at workmanship of this standard!). I suppsoe we should give a little credit to the 'tiler' for having installed an RCD at all!I'm assuming there's overcurrent protection further upstream...
Just wondering what's going on with a main switch half way along a newish eaton consumer unit?
It isn't as if those MCBs are rare!
