Hi All,
In planning for a loft conversion I'm putting in an interlinked and mains powered fire detection system. I'm going to run all the wires myself and have an electrician wire up, test etc. I can't find definitive information on how many are required and where. The plan is to use as many smoke detectors as required as well as a heat detector in the kitchen. The property is a mid terrace Victorian and will have a loft conversion. The stairs will be closed in and the CU is by the front door. Loft entrance door and main door to living area at bottom of stairs will be FD30. Am hoping the 1st floor room doors can remain as they are. They are in good condition but aren't fire rated and no intumescent strips.
Floor plans below.
Thanks in advance.
Floor plans below.
Thanks in advance.
