- Joined
- 26 Aug 2016
- Messages
- 6,830
- Reaction score
- 1,009
- Country
Well I heard the iPhone 9 will have a built in mft appYou taken some test kit on holiday????
Errr... no.You taken some test kit on holiday????
So why write thisErr... no.
when you have already said the following which, without any qualification, implies poor or non-existent EFLI?I think that fault loop readings might also be a bit dodgy.
No earth of any sort - not even incidental via main bonding because there is none of that either.
I was replying to this.:So why write this
Shockingly there are still some sparkies that do not know the difference between a voltage operated trip and an RCD, and will assume this install is fine. Obviously would/should fail a trip test.
It's a changeover switch on one side of the trip coil.What does the test button on a VOELCB do?
