exhaust manifold can hit temperatures of between 600-800
Not at the cat though is that not further down?
You wanted to know why we were negative about flueless gas fires - we told you. Doyle put it very nicely.
And your welcome.
adiwill said:Dan_Robinson said:What is the temperature of an exhaust from a car? Lower than that of the gas fire I would wager.
no mate a car exhaust manifold can hit temperatures of between 600-800 degrees in the right circumstances. and no, i'm not a mechanic.
look, all i want is facts about cats failing on flueless fires.. despite all your arguments none of you can give me that. its pure speculation and scaremmongering.
conversation over... sorry, i'm not convinced. None of you have put up a good argument as to why these fires are actually dangerous.
adiwill said:look, all i want is facts about cats failing on flueless fires.. despite all your arguments none of you can give me that. its pure speculation and scaremmongering.
Dan_Robinson said:exhaust manifold can hit temperatures of between 600-800
Your missing the point, there dangerous because they haven't got a flue.look.. you're all missing the point. Everyone on here came on and immediatley said that these fires are dangerous because they have a cat fitted,
How much do you know about the combustion process of natural gas, and the things that can go wrong with that process?ones which a gas fire simply cannot create.
There's a 14 year old girl who is no longer alive because the cat failed on the new fire in her home.none of you could give even give me ONE example of a cat failing on a gas fire, let alone causing death.
adiwill said:the death posted earlier was due to an incorrect fitting or manufacturing error, and therefore NOT directly a failure of the cat during everyday use, which is what you're all implying that these fires are prone to.
clutching at straws now..
