Arctic Cable?
14 Mar 2007
Yorkshire
Do I need to use arctic cable from an outside (switched) socket to my greenhouse?
The length of cable would be no more than 3 metres but probably closer to 2 metres. It would be left connected to the socket all of the time. Don't know if it makes a difference but I live in Yorkshire so the winters are milder than some further north.
It would be better to make a perm job of it if its connected all the time.
If you dont want to do that then make sure your arctic cable cant be damamged by spades, children, rats, etc.
Two things:
Will your socket be watertight with a plug in it??
Is the socket protected by an RCD??
Two things:
When I said it will be plugged in all the time, that's not quite true, I will want to be able to unplug it a couple of times a year to plug in my hedge trimmer. There will only be about a metre of cable outside I can run it through some conduit and cover with some aggregate. There's only me and the wife and I'll know where it is, plus it will visibly come out of the greenhouse and from the socket. The greenhouse is also going to be changed at some point in the future so I don't want anything too permanent.
The socket is a Masterseal RCD IP56 and it comes off its own FCU and yes it is watertight.
Thanks very much for the safety advice, but back to my original question, does it have to be arctic cable?
Yes, its made for cold outdoor use. Down to -20ºC. Plain old PVC will crack up at low temps.
Not sure if arctic is UV stabilised (anyone??)
Normal PVC will break up in sunlight (in time).
Not that you'll get any sunshine in Yorkshire :LOL:
AFAIK arctic is UV stabilised, and therefore suitable for use outdoors.
However, it must NOT be buried, regardless of how short a run, conduits etc.
I wouldn't leave it on top of a lose surface because of the risk of it getting accidently burried, damaged by people stepping on it etc.
can you give us more information on what the physical layout of things is?
This old photo may help. The Weatherproof RCD socket is fitted to the stand where the hosepipe reel is. On the ground between the stand and the greenhouse is aggregate.
What about if I cover it with one of those cable cover strips? Or any other suggestions.
