We recently moved into a new house and want to replace an old plastic light batten in the bathroom with a new spotlight.
However, there is no earth wire on the lighting circuits (it could have been cut right back but I presume not as the house is quite old).
The new light does require an earth cable (metal base plate) and I was wondering if there was another option besides a rewire.
Above the light fitting in the loft there is a cold water pipe leading to the main header tank. Would it be safe as a temporary measure to run an earth wire from this pipe specifically for this light fitting or not?
Cheers for any answer
