Belkin Wireless Logging On
Status
Not open for further replies.
You dont have a floppy/cdrw/pendrive/external hdd to mention but a few ways of transferring a file from one pc to another?
desbarron said:
Cant use the winsocks fix as the computer is not on line.
#Des
I obviously meant use a PC that was Internet connected to get the file and then transfer it via whatever means you have.
ok
If your router is setup as a dhcp server, and you are getting no conenction, then how will you get a gateway?
Are you SURE you tried a cable? can you try this cable in another machine?
There is limited connection.
Normally the computer/software sends a request down the line and a gateway is assigned. I tried the cable and it works fine with another computer.
ok try this please
start/run type cmd then hit ok
onthe black screen, type ipconfig /all
copy/paste the entire message. (right clikc on the black box, select "mark" then highlight all the text then click your button to copy it.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Jane E Barron>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : 72f697e864ed414
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : SiS 900-Based PCI Fast Ethernet Adap
ter
Physical Address. . . . . . . . . : 00-0B-6A-7D-D9-1B
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Belkin Wireless 54Mbps Desktop Adapt
er
Physical Address. . . . . . . . . : 00-11-50-08-2E-EC
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.208.156
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
ok cool, can you please try it with the able in as well (sorry should have mentioned that before)
Is your wireless security disabled or enabled at this time?
Sorry but what is an able and how to I check Wireless Security settings.
Who set the host name to be this (above), and why?
With all the help you've had are you really, genuinely, unable to understand that the PC's view of the cable is that it's disconnected?
Has the troublesome PC ever been connected to a network? :?
I wasnt even going to go there...
Thats why I wanted him/her/it to plug in the Cable and do an ipconfig
I still think this is either a wind up or someone that is genuinely to thick to own a pc - wont be the first one I've met... so unless they start helping us to help them, they are stuck with a pc that is offline as far as I'm concerned.
I could see that, which is exactly why I did. :twisted:
Thats why I wanted him/her/it to plug in the cable and do an ipconfig
I know that too, and you and Igorian were being so polite and nice that I couldn't resist a dig at desbarron.
The media is diconnected because the cable is out of use and the wireless is working. The PC is receiving the signal I just cant log into the server. Insulting me is not solving the problem. Everything works fine except Btyahoo is not recognising this computer and sending the gateway. The pc worked fine till I had to move it to install wiring and plumbing under the floor. Belkin couldn't help Btyahoo could'nt help. I just hoped someone out there could.
its obviously not - one of the reasons you were asked to try a cable
Oh we are logging onto a server now are we? assuming you got the words "router" and "server" mixed up - which wouldnt suprise me in the least,
would indicate a wep/wpa/other wireless issue which is why you were asked to try a [C]able..... and post the results
Neither is you not doing as people advise
so its not working - fine or otherwise
If you cant be assed helping yourself by carrying out simple tasks that we ask you to carry out - without being sarcastic, then I suggest you try ringing Abdul at BT again - I'll do you a favour and prepare you for his first question- "Have you tried restarting the computer"
Status
