Hi all!
I've recently moved and the home I moved into has a kitchen sink with a 1&1/2 bowl kitchen sink.
I have a 1&1/2 kitchen sink bowl. The 1/2 sink waste is completely blocked and doesn't drain at all. The full sink bowl runs with no problem whatsoever.
I've removed all the pipes from under the 1/2 sink bowl and there is no blockage. Also, the 1/2 sink bowl connects into the waste pipe further down from the full sink bowl so the blockage cannot be anywhere else.
Everytime I remove the pipes, I empty the u bend then when I run the water into the 1/2 bowl, the water seems to fill the u bend and then stop moving.
Can anyone offer advice? Is this some kind of water pressure issue preventing water from pushing down the 1/2 sink waste?
