I use 1100 feet/second because I'm lazy, so with 3.28 feet/meter and 11,000 feet/second you have 11,000 feet/second x 1 meter/3.28 feet. The feet cancel out so it is dimensionally correct and you're left with 3400 meters/second.
You seem to want to reject the null hypothesis which is "I am not full of caca."
If you reject it when you should have accepted it, it is a type I error - a false positive, and a type II error is a false negative.
Don't forget that both errors cannot be minimized at the same time.
Make your case.
Of course, no one can prove a negative so I myself cannot prove that I am not full of caca, assuming one is either full or not full of caca.
BTW, my BMI is too high so I'm trying to lose weight and so I need to make sense of my varying indicated weight and my food intake and my energy output in order to come up with a regimen that works.
One of the variables is that, at present, I assume I am full of about 10 kg. of caca, but I could be wrong.
Always a pleasure, Monkeh. . .
