I have a water feature that plugs into 13amp socket, but the cable is only 2 metres in length, I want to put the Feature further away from the socket and also bury the cable under the lawn. What cable do I need, and does it have to be in conduit?
oggers said:Hi Silver:
You can use steel wire armour cable //wiki.diynot.com/electrics:cable_types:swa. (600mm deep, and don't forget your RCD protection for the garden if you don't have it already, plus you need approval for a new socket out there
plugwash said:do not assume that just because someone calls themselves an electrician that they are going to do it properly.
