Climate Change
WTAF is GISP?
A scientific research project that was twisted on sceptic websites.
As prof. Richard Alley said,
“So, what do we get from GISP2? Alone, not an immense amount. With the other Greenland ice cores… and compared to additional records from elsewhere, an immense amount… Using GISP2 data to argue against global warming is, well, stupid, or misguided, or misled, or something, but surely not scientifically sensible.”
Yep exactly as I said climate doomers like to either ignore the GISP findings or attempt to debunk it because it doesn't fit in with their unprecedented never before narrative
The current rate of warming is, according to the project, the greatest in many thousands of years.
Still, you know better than a published and peer-reviewed professor.......
Go research the results yourself form the people who actually ran the project instead of quoting 1 climate doomer prof trying to debunk the findings
Again and again you allow yourself to be schooled - you start blabbing about climate like you know it all - but then show yourself up like you did over the plane tracker you also knew nothing about
For someone 'schooling' me you've told me absolutely nothing. As usual to get any clear answer I have to wait for someone else to explain your drivel.
So what does this GISP (1?2?) prove or disprove? How does it show this current heating trend is not an anomaly? Also do you even know what anomaly is?
Why would anyone take the project staff at their word, and discount those of anyone who read their results and offered a differing opinion?
Why are you afraid of peer review?
I am not doing your reading for you - I cannot beleive that you are posting on a climate change thread like you know everything but have not got a clue about the GISP 1 and 2
In a nutshell for you.
GISP =Greenland ice-sheet project part 1 and part 2
They drilled an ice core so they could look back over 1,000s of years.
They found there have been many sudden temperature increases
Some as quick as 10s of years.
Higher resolution records were indicating considerably less than half a century for a climate warming further studies narrowed the time frame even further James White in nature July of 1993 found the new ice cor ice core results bring rapid climate change to our doorstep changes up to 10° centigrade in a couple of decades or perhaps in less than a decade appear possible the data now revealed that the climate was able to change a full 10°Centigrade in perhaps less than a decade
the ancient warming far outpaces what the world is currently experiencing keep this fact in mind when you read someone arguing that the current global warming rate is unprecedentedly fast
This is based on the results of ice cores -from peer reviewed scientific studies from trusted sources
The climate doomers dont like the findings as it drills a big hole in their "unrepresented -never before " narrative.
GISP =Greenland ice-core project part 1 and part 2
GISP2 was in 1997, there were better quality larger studies since then to replicate it and get more cores to try to reduce error.
If you want a rapid change of temperature you're looking at the Holocene era 8,000 years ago.
The temperature shift in Greenland is believed to be a result of the equivalent of the Atlantic conveyor collapsing. That will cause major localised temperature changes very quickly once it happens. The cause of the overall temperature shift was due to the earths orbit and vulcanism, which isn't relevant now.
Great news, we're making the same sort of catestrophic changes that normally need orbital mechanics or supervolcanoes.
The temperature shift in Greenland is believed to be a result of the equivalent of the Atlantic conveyor collapsing. That will cause major localised temperature changes very quickly once it happens. The cause of the overall temperature shift was due to the earths orbit, which isn't relevant now.
Great news, we're making the same sort of catestrophic changes that normally need orbital mechanics.
Now you are an expert :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: All of this has already been gone over on this thread last June --- when we had another hot spell:rolleyes:
Thanks to @Brigadier I did discover the EPICA Antarctic ice cores which show almost the opposite temperature jumps, alongside the same millennium long temperature trends thanks to orbital mechanics
Its almost as if you can't base your view of an entire planets temperature on a single location! And that gradual changes to global temperature can make catestrophic changes to local climate.
