It could be the gas setting is wrong but that needs an RGI to check/correct.
But its most likely all your repressurising has brought a continual stream of new water into the system and caused lime scaling inside the heat exchanger.
You could close off the largest radiators and run for a few hours with X200 in the system. After a few hours when the system hopefullt has quietened down open the other rads and leave it in the system.
Tony
Tony
