    Dismiss Notice
Conlock conduit
Discussion in 'Electrics UK' started by ^woody^, 2 Mar 2021.
  1. SimonH2
    SimonH2
    4 Nov 2010
    5,707
    Thanks Received:
    579
    Cumbria
    Country:
    At the last house I finally got fed up faffing around getting boards up - and I treated myself to a nail puller. It's like a slide hammer, with jaws on the end. Jaws open either side of a nail, hammer down till the jaws have sunk far enough into the wood, then lever over and the jaws grip the nail head and pull it out. Leaves a rectangular indentation, but the least damaging technique I've found. I pulled all the nails in one room and put screws in - no sqeaks :D
    There isn't on our extension. The original house is the style where the walls are lower than theupstairs ceilings which slope down with the roof line for the last foot or so. The extension (teed off the back) has the same roof profile, but instead of a regular ceilng, the lounge has a vaulted ceiling - so no attic at all. There's a spot right at the apex of the gable where I could drill through from the outside and fish a wire alongside the ridge beam - but otherwise I'd come through into the lounge.
  2. Sponsored Links
  3. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    It's not the nails which are the primary problem with T&G but, rather, the need to cut through the tongues without damaging the sides of the boards too much.
    Kind Regards, John
  4. RF Lighting
    RF Lighting
    31 Mar 2006
    19,949
    Thanks Received:
    1,344
    Leeds
    Country:
    Get yourself an oscillating multitool. You’ll never look back!
  5. SUNRAY
    SUNRAY
    28 Jul 2009
    4,342
    Thanks Received:
    304
    Kent
    Country:
    A trick I learnt from the chippies when working in a grade 1 listed building. Removing the nails from 3 adjacent boards generally allows the removal of the centre board without cutting the tongues. It's tricky/fiddly and probably needs handles [blocks of wood etc] fixed by screwing into the nail holes.
  6. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    I have one, but it's still difficult to leave the edges of the boards intact.
    Edit: ... and, as I've just written to SUNRAY, there are lots of 'hidden' nails through the tongues, which makes cutting through them 'fun' :)
    Kind Regards, John
  7. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    I've tried that, with varying success. The Victorian boards I'm talking about are very narrow (just 3"-4"), so it usually has to be at least 5 boards, not just 3 - and they tend to be very long, and go under massive (around 10" x 2½") skirtings.
    Worst of all, not only are the boards very tightly butted against each other, but most of the nails are through the tongues, and hence not even visible/accessible from above.
    Kind Regards, John
  8. SUNRAY
    SUNRAY
    28 Jul 2009
    4,342
    Thanks Received:
    304
    Kent
    Country:
    ooo that's narrow for boards that age.
    Nails through the tongue is a ruddy great game changer, the only advantage there being once the tongues are cut there is noting to stop it being lifted out. At least being that narrow they will bepresumably flexible enoughto allow them to bow to be slid from under the skirtings.
  9. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    We have 'the sublime and the ridiculous', in different parts of the house. The Victorian ones are as I have described - T&G, 4" or less wide (and tightly butted). The Georgian ones are square-edged (not T&G) and are mainly 10"+ wide (varying widths), but are "a labour of love" - the undersides are not planed, but each place that they pass over a joist (generally 3" x 9" or thereabouts) the underside has been chiselled/axed so as to sit perfectly on the joist!
    True ... eventually. However, cutting tongues which have nails through them is 'interesting'!
    I'm not so sure about that. For a start, they are pretty thick but don't forget that the skirtings are very deep.
    Fortunately, it's a long time since I last had to play that game, and I have no intention of doing so again any time soon, if ever!
    Kind Regards, John
    • Like Like x 1
  10. Sponsored Links
  11. SimonH2
    SimonH2
    4 Nov 2010
    5,707
    Thanks Received:
    579
    Cumbria
    Country:
    I'd like to say that's what I was thinking when I had to lift part of the main bedroom floor - done with those horrible big sheets of weatabix. Had to carefully trim edges off to get them up as they'd been done before the skirtings were put on. Of course, by the time I;ve got them to the point where I can disengage the T&G and lift a board out - when they go back there's a gap which is at least hidden once the carpet is down. At least the T&Gs weren't glued which I believe is required practice these days - a friend has recently done a loft conversion, he tells me the requirement is that the sheets are both glued at the edges, and onto the joists :evil:
    One day, there'll be a lot of new T&G (engineered) planks going down in some rooms - and a lot of weatabix being thrown out.
    But, I can understand why builders love these big sheets - it's a lot less work and they DGAS about future maintenance.
    Amusing, if it weren't so bad, the house my mum was looking at had some fancy boards declared to be waterproof. The vendor was going on about these waterproof floor boards - while I observed that in the bathrooms, they were full of big holes for the pipes. So the one place where being waterproof could be an advantage, was also the one place where it wasn't :rolleyes: Mind you he was "selling" lots of features which I could see were just "the bare minimum building control would let them get away with".
  12. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    Good grief!
    Kind Regards, John
  13. SimonH2
    SimonH2
    4 Nov 2010
    5,707
    Thanks Received:
    579
    Cumbria
    Country:
    That's could be a summary of my thoughts at the time :whistle:
    Also not allowed, or perhaps only allowed with such restrictions as make it impractical, is embedding the ends of joists into the inner leaf for support. The standard now is to bolt a hanger plate (basically just another joist) to the wall and fix the joist ends to that using brackets and a lot of nails - meaning that along two walls, there's a lump of 2" thick timber, typically full depth of the under-floor cavity, bolted to the wall where you'd want to put cables. First fix, no problem - just drill holes and thread the cables through. Later maintenance/modifications - :mad:
    Yes, modern building standards are for non-maintainable buildings. I wouldn't want to buy a new build, not unless I had the opportunity (and budget) to have it "customised" for maintainability - but if I had that budget, it would be easier to just have one built to my spec (I wonder how many trade people would walk off the job before it was done :unsure:)
  14. SUNRAY
    SUNRAY
    28 Jul 2009
    4,342
    Thanks Received:
    304
    Kent
    Country:
    My daughter purched a new built some 10-12 years ago and they were specced as glued joints and onto joists and screwed. However when I discovered the kithen appliance switch panel and cooker point were fed by 2.5mm² t&e radials on 32A MCB's [contrary to the spec and test cert] 1st floor boards had to be lifted to run the new cables and the boards were not even fixed down.
    Oh yes builders love the big sheets.
    Most access these days seems to be from the ceiling rather than the floor, I can understand why.
  15. RF Lighting
    RF Lighting
    31 Mar 2006
    19,949
    Thanks Received:
    1,344
    Leeds
    Country:
    Yes the standard is now chipboard sheets glued on the joints and glued and screwed to the joists with PU adhesive. This is to make the board edges / joints water resistant and to stop the squeaking of floorboards which plagued so many new build houses for a long time.
  16. JohnW2
    JohnW2
    28 Jan 2011
    46,289
    Thanks Received:
    2,985
    Buckinghamshire
    Country:
    Maybe so, but I think that my "Good Grief" comment still has to stand :)
    Kind Regards, John
  17. RF Lighting
    RF Lighting
    31 Mar 2006
    19,949
    Thanks Received:
    1,344
    Leeds
    Country:
    Are you surprised that house builders are now being forced to actually do something properly?
Loading...
Share This Page
