I have recently been attempting to add lightbulbs to an outside light (lantern style). Max wattage for this is 40 watts...so I buy 40 watt bulbs. I considered adding a energy saving bulb (9 watts if I remember correctly) as with the other outside light on the front. Turned the switch on (indoors) to check if ok; basically it lit for a few seconds before gently 'expiring'. So I tried a normal 40 watt candle bulb this blew...and another...this blew also.
I can't for the life of me work out why this would happen? Has water somehow entered the connections inside the lamp? The light was connected by the guys building the kitchen a couple of years ago - it isn't as far as I know on the lighting ring (we only have one for both upstairs and down) and may have been inserted via a spur on the mains...? The fuses are never effected when this occurs.
Any usual suspects you can think of folks?
Thanks.
Thanks.
