hi please can some clarify, my mate is going to fit what i think is a 26amp pizza cooker into a cafe. In the cafe they have already got a 7mm flex point out to one of their cookers in there, that goes to a wall outlet (no switch just a cover with a hole in it where the flex comes out into the cooker).
My mate said you can bridge into that single 7mm supply and run both cookers off it. I said if they need to put the other cooker in their then they will need an addtional radial supply from the consumer unit with correct mcb 30amp (not sure on pizza cooker amp rating) but I said id ask someone to check before he goes ahead.
PS I you could run say x2 20 amp cookers on a single 40amp mcb but still think separate radial supply is best!
Please let me know best method to solve this any help appreciated
thanks
thanks
