Are your existing taps fitted with flexible hoses ? If so ,what is the flow like ?
No, they're like this. And I have hot & cold water tanks, so flow relatively low...
Dont forget to remove all traces of the fibre washer ,and fit new washers .Keep the pipework like that if you possibly can....if your luck is really in you should be able to disconnect, swing the pipes out of the way and fit the new taps and reconnect.
Some sealant where the pipes enter the taps can’t do any harm!
John![]()
John![]()
Probably need to remove the basin. Its sometimes possible to ease the pedestal out ,just enough to get access to the big back nut ,but that depends on a number of things like ,is the pedestal base encapsulated by flooring / tiles etc ,and can the basin be eased from its wall anchorage sufficiently ,is there any play in the pipe work.
A judgment call as to if its gonna be quicker to just take the basin out.
Leave the basin where it is, measure from the front of the pedestal to the floor then cut a piece of 2 x 1" or similar, get your shoulder under the basin, push up slightly remove the pedestal and prop it up with the wood.
Sounds like a reasonable plan ,but I wouldn't use flexible hoses. The rigid pipework will give much better flow.The basin was very loose when I moved into the house, and the entire ensuite is fully tiled, so I had to silicone it to the tiled wall, as the fixing screws were just rotating in their holes. Not really how I'd like to have done it, but I couldn't see any alternative. But at least I know how to remove it again... and the base just fits into a slight recess in the floor.
My plan – unless you advise me differently – is to remove it, take everything off, clean it all up, install new waste and taps; flexible tails on the taps; fit isolators to the risers; and hope I can get it all together again without leaks![]()
...or at least one and two thirds of them
Then the taps you are thinking of getting ,coupled with flexi hoses ,are gonna be a lot worse.
Are your existing taps the screw down type ,or quarter turn ,to turn on / off ?
